RV-6A - GBC
Date: 12-16-2010
Number of Hours: 11.00
Manual Reference: F/I Option Kit
Brief Description: F/I housing assembly
Tedious and inefficient process but managed to kill a long day with fabricating the final components of the heat vents, enclosure, lots of nutplates, and other details of the fuel injection option kit installation. Shaped up to be a very solid housing but very complex to adapt and fit.
Bent up on the manual trim cable attach to get a better angle on the cable, and routed the cable through a couple of holes (joined unibit holes), to provide a tunnel exit. Needs a little work on a cable clamp to secure the cable position.
The seat pans got nutplates for the custom attach angle and the remaining nuplates in the F-983 fuel selector housing were installed. Lots of edge prep, priming, and test fitting. It might be noted that I did NOT follow one item in the OP-21 plans, and instead riveted the fuel filter housing to the fuel selector housing. The plans call for #6 nutplates and screws. The entire housing 'should' be removable by sliding forward 1" and lifting it, once the top plate of the selector housing is unscrewed.
Took a quick look ahead on the firewall position of the TG-10 heat diverter, and will need to research.
Still need to install nutplates on the floor stiffeners for the tunnel cover to be secured, otherwise, looking close to complete.
Manual Trim Cable routed
Fuel Selector plate secured
TG-10 heat diverter?
