Worked on the Elec Flap installation. EF-602, EF-601 and related components. Ran into mounting problems with nutplates in the tunnel ribs for the UHMW center block. Want to add 1/8" alum spacers to the end blocks to fuse bulkhd mount.
Prelim of Elec Flap motor mounted in EF-601 ... good fit, very happy with result. Minor mod to spacer (5/16" vs 1/2" alum)
8.1.06 - Update - filed off some casting 'flashing' on the gearbox pivot. Clears up the fit.
