With the Vans order, I received the 'thin' washers required to correctly fit the Heim joints with proper spacing.
Spent way too much time getting the washers in the very restricted underfloor areas. Had to finally remove some things to have access. The fwd elevator tube was unscrewed so that only the Heim joint had to be attached, then re-inserted the elev tube.
