Gene stopped by for a few minutes and helped to insert the Rt wing, wiggle it into position and I was able to get the initial tapered pins in-place. After that was several hrs of working through pins, and the bolts to progressively insert a pattern of larger and small bolts in outboard and inboard holes.
This was important to make sure that every critical area was aligned and fastened before finding out that some bolt was impossible to insert. When it comes into alignment the remaing bolts are easily tapped into each hole with minimal effort.
