RV-6A - GBC
RV-6A QB
Tank - Attach bolts
Finally, drilled the holes thru the tank to fuselage attachment - after receiving the order for the correct nutplates & bolts.
Will now be able to remove wings far enoug to finish the dimples for the wing root fairing and 'permanent' assembly of the wings to fuselage.
Still need to remove tanks and rivet MK1000- nutplates to fuselage brackets. Then cut the slots in the tank brackets.
Left - Forward side
Left - Aft side (no rivets)
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
