Confirmations of J4 and J5 connectors on the VP-100 and moving the harnesses from the test bench to the equipment bay. Routed the contactors for Main Bus, eBus, and Starter. Added labels and terminations, routed ground wires to FW block.
Adjusted J6 connector harness, too. Put in equipment bay to be routed next.
