Cut the remaining stiffeners from the strips, prelim debur. Dimpled the new spar and clecoed to new skin. Added the bottom rib and match-drilled the components of the reinforcement plate and angle to the assembly. Match-drilled a few holes on the bottom rib for preliminary alignment. Remaining holes will await bending of the trailing edge of skin.
