RV-6A - GBC
RV-6A QB
Avionics - tubing, harnesses
Secure aft compartment tubing and harnesses. Routed tubing in Lt fuselage. (Need to crawl in the tailcone to finish tie-wraps.)
Wires routed around the bulkhead and across rails to ADAHRS. (Need to finalize D9 wires, and add connector to OAT wires.)
Drilled additional hole for AOA tube, deburred, added grommets and routed the tubing to cabin under armrest.
OOPS - fixed now
Tubing secured
Harnesses secured
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
