RV-6A - GBC
RV-6A QB
Cowl - Upper, Hinge Attach
Used a strong LED work light under the top cowl to illuminate the hinge holes/alignment.
Drilled conservatively 'tight' fit, and only pdrilled about every 4 or 5th hole for now. Will remove the cowl and match drill on the bench.
Work light under cowl
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
