RV-6A - GBC
RV-6A QB
Engine Baffles - 10th step
Trimmed and deburred both sides, then added brace. Cut two holes because this panel will be a pass-thru for the 4" tube to the oil cooler.
Still have to trim the front sides to conform to the inlets in the top cowl. And need to fabricate a missing bolt/nut located on the aft engine case.
Drop on the top cowl, and then the bottom to test alignments and interference.
Left aft - Added brace
Almost all trimmed
Test fit - cowls
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
