RV-6A - GBC
RV-6A QB
FW - Oil cooler mount
Aligned the FW mount, drilled, deburred, and clecoed on for final test fit. Bolted the oil cooler to the mount, Awkward but achievable.
Think the proper rivets to the FW would be steel structural pull variety.
Determined there is no clearance for an adjustable shutter. Option to do a ground adjustable, removable shutter.
Drilled & Clecoed
Bolts test fit
Inboard bolts
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
