RV-6A - GBC
RV-6A QB
Rollbar - assembly & fitting
Still carefully assembling and testing the fit to match the rear window.
Added the new splice plates to get the width fit closer.
Cut the hinges for the top & bottom cowl sides, and the pins with welded tabs. Task for another night.
80% drilled and tested
Cowl top to bottom hinges
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
