Slow progress on the first of the wiring/soldering tasks, wiring the LED holders for the wingtip (position and strobe) and secure to a barrier strip. Also spent some time on ordering additional wire and connectors, and documentation of the cirucits.
Almost ready to take this to the airport and compare it to some of the EAA chapter member planes and lights.
Barrier strip will be secured to the inside of the wingtip after the light recess is fiberglassed into the wingtip.
A single Molex plug will be used to connect the landing/taxi light, each strobe & position component. Need to assemble the appropriate colors, sizes, grounds, and pairs for the wing conduit to handle the run to the fuselage/panel.
