RV-6A - GBC
RV-6A QB
Pitot Option
Drilled pitot month hole
Installed the anodized and unheated pitot mount outboard of the inspection port in the bottom of the left wing.
Misplaced the instructions and need to get rivet pattern info from vendor before drilling the rivet holes.
Need to remove three existing rivets from the aft edge of the main spar, then match drill into pitot mount and re-rivet.
Need to drill through the tube and match to the fasteners on the Dynon pitot.
Dropped into position
RV-6A QB Home
3573
222
440
140
392
Finishing Kit
165
457
156
864
Gear
109
QuickBuild RV-6A Kit
455
Workshop
