Eddie's Zodiac XL Project
Date:  8-29-2010
Number of Hours:  1.00
Brief Description:  Hung rudder and elevators
Anne-Marie gave me a hand to hang the rudder and elevators, after which I measured the throw that each elevator has, at the moment its 30 degrees up and 25 degrees down, I'll need to consult the plans to confirm that this is correct, I'll also need to adjust the inboard bearings on each elevator as they are both rubbing a little.
I now need to dimple the tops of all the rear formers before I can install the rear skin. I also need to route a wire through for the rudder tail light, so will probably do that before the top skin goes on.
Rudder installed with temporary pins
Elevators installed
Elevators installed
View from the other side
