Brief Description: Made and riveted centre spar parts
This work was done over the space of the last week, but I have condensed it into one log entry, it took me much longer than I thought to get my head around the plans and instructions....and I thought that I was getting better at this.
There is lots more work here (holes to enlarge for snap bushings etc. parts to make or trim down to save weight) than the pictures suggest, plus there are lots of nut plates that are not obvious from the photo's.
Anyway its done and I am pleased with the end results, there are one or two rivets on the uprights that have a smile on them but its not bad enough to redo and risk making it worse.
Front of spar with uprights riveted and center cover brackets in place
Centre view of spacers
Rear of spar with control stick attach brackets and uprights riveted
