There is lots of cutting and fitting required here, especially around the tire, the wheel cut out in the spat as provided is just way too small.
I have a pretty good fit here, I just need to elongate the hole on the rear section of the spat so that I can drag the rear in towards the fuselage a little more and then I will remore enough material around the tire so that I have good even clearance all the way around.
