I bought the ready made intersection fairings for the gear legs and wheel pants from 'Fairings etc.' and the fit is just magic, well worth the money, also they save you the hassle of having to orient the leg fairings so that the are parallel with the airflow, as the intersection fairing position has already been predetermined by the way it fits to the fuselage.
Installing the hinge after cutting the fairing down to the correct length
Rear view
Hinge riveted and intersection fairing pushed into position.
