Eddie's Zodiac XL Project
Date:  4-8-2011
Number of Hours:  3.00
Brief Description:  Brake line install
Pretty strait forward installation, although I have changed the routing around the gear legs where they meet the engine mount so that they do not interfear with the fairings, this only became obvious after I started installing the right gear leg fairing. The tubing needs to hug the rear of the gear leg for as long as possible before it meets the engine mount.
Right side brake line installed
Left side brake line installed
Both lines connected to the firewall
