Eddie's Zodiac XL Project
Date:  4-16-2008
Number of Hours:  1.50
Manual Reference:  VA 146 + HS-411
Brief Description:  Squeezed rivets for the elevator hinge
Tonight I started by squeezing the rivets in the center elevator bearing, this was then followed by tapering the front spar re-enforcement angles, one down one to go.
Using the rivet squeezer I set my first rivets of the project
HS-710 with one end tapered
HS-710 with both ends tapered
