Today I spent lots of time riveting and epoxying the rear vertical and bottom horizontal hinges to the fuselage and cowling.
There are a few rivets at the bottom of the rear vertical segments that I can't set using the squeezer, so will need to see if I can buck them, although things are pretty tightin that area, guess I shall see.
Nearly time to move onto the engine baffling...
Hinge with epoxy underneath and riveted to the cowl
