Eddie's Zodiac XL Project
Date:  6-26-2011
Number of Hours:  5.00
Brief Description:  Top and bottom cowl install
After drilling the top cowl to the Camloc mounting strip, I discovered that the right rear top corner was out of alignment, so I had to re-drill a few holes, which has left a slight gap that I need to do something about.
Also on the left side cowl join, the center section has a gap, so more sanding is needed around the front and rear of the cowl to get this all lined up properly, once this is done i can then trim the rear and bottom cowl sections to match the fuselage.
Left side, more sanding to do, the center join still has a gap.
Right side join is perfect so I will try to leave it along...
Both inets have a good fit.
