1. Installed flap controller 2. Wired flaps to control sticks and confirmed flap operation 3. Wired top-hat switch to ailerons and elevators and confirmed operation 4. Wiried press to talk, pilot and co-pilot to radio and confirmed operation 5. Wired auto pilot disconnect and confirmed operation (only pilot side is working at the moment, seem to have a wiring fault on the co-pilot stick) 6. Wiried aileron and elevator position indicators to Skyview Display 7. Calibrated aileron and elevator trim sensors on SKyview 8. Documented all wiring connections
Left to do;
1. Wire strobes (tail strobe and left and righ wing postion strobes) 2. Wire taxi and landing lights 3. Install aileron auto-pilot servo 4. Wire aileron auto-pilot servo 5.Plug in wings and confirm it all works.
Tidied up the centre tunnel wiring run
Moved the mess to under the pilots seat, a littile tidy up and it should be good.
