Eddie's Zodiac XL Project
Date:  5-6-2012
Number of Hours:  3.00
Brief Description:  Left wing tip and right elevator
Another job down, got great shine out of the wing tip, managed to put a run in the tip of the elevator so will have to sand that back and re-shoot a single coat. Its quite hard to hold something in position and paint at the same time so the end result was too much paint on the tip...
Even after applying paint the elevator weight still applies positive force which means that I am not adding too much weight.
Repainted after filling pinholes on the edge where the halves are joined
Other side
Other side
Right elevator after first coat of paint
