Brief Description: Started the fiberglass windscreen fairing
I masked off the windscreen and forward turtle deck before laying up the fiberglass cloth, teh resin has soem black pigment mixed into it so that when you view it from the cockpit it will be black to blend in with the top of the glare shield.
I then applied peal ply to soak up the excess resin, once the rewin had cured, the peel ply was removed and I applied a layer of filler to cover some of the small voids and also to start creating a smooth surface for painting. It does not look great at the moment, still lots more sanding and filling to do....
I also recieved my order from JD Air Parts of two sets of rudder peddle extensions, these are meant to stop you riding the brakes while taxing etc. beautiful wokrmanship, the extensions appear to be milled aluminium which has been powder coated black.
Left side with a layer of filler over the fiberglass
