This was fairly time consuming as the front support block had to be drilled and tapped before beign installed, the rear supports just had to be cut, shaped and installed.
The rear handle jsut needs to be centred and back drilled, counter sunk and a hole drilled for a washer and split pin to retain the handle.
RIght side brackets made and strut installed
Centre handle drilled, retaining washer and split pin installed
Left side brackets made and isntalled along with gas strut
