Eddie's Zodiac XL Project
RV-7
Firewall
11-22-2010
Install Shunt and cable glands
Back into the building after being overseas in Bulgeria for a few weeks.
I installed and connected the amps shunt between the output of the Master solinoild and Starter solinoid.
Also connected the cable that will terminate the +ve volts for the Master distribution block, this feed is taken on the output of the shunt.
Checked that the Master relay works by grounding the center post, the one with the yellow heat shrunk diode connect to it.
Battery cables terminated and connected
COnnection between master soliniod and Shunt installed
Cable gland installed and EMS wiring harness poked through
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
