Eddie's Zodiac XL Project
Date:  10-18-2009
Number of Hours:  5.00
Brief Description:  Center fuselage - Back drilled, deburred, dimpled
Today I back drilled the entire center section of the fuselage, there are a mountain of holes and man nahdling the structure on your own is a bit of a challange, so that you don't bend anything as its rotated.
With everything back drilled it was all disassembled, edge finished, deburred and dimpled.
I still have to debur the bottom skin and dimple before I can start to etch prime, but perhaps I'll do this in two batches. All the ribs and smaller parts first and then the bottom skin.
All the ribs deburred and dimpled
Center spar supports back drilled and deburred
All the spacers deburred and dimpled as required
