This morning I moved the rear fuselage off the saw horses to make room for the the center fuselage assembly. You can see it standing on its end at the rear of the first photo.
I started by cutting the enlargement holes in the ribs at the required spots to allow the stick assemblies to move freely. I then made the tops of the two cneter ribs removable and installed all the nut plates as per the instructions. With this done the ribs where clecoed to the rear spar.
The rear baggage bay ribs are then clecoed to the rear seat back, they are still in their blue plastic because I have not edge finished them yet.
All center ribs preped and nut plates attached
Front view, pilot and passenger seat floor, behind center rear spar. Blue ribs are the baggage bay
