Eddie's Zodiac XL Project
Date:  1-4-2012
Number of Hours:  1.50
Brief Description:  Fuel line fittings for connection to wing
Its getting really hot early this morning, so I did a few small jobs, such as flare the fule line fititngs for connection to the wings, and moved both of the capacitive converters from behing the spar (I was not thinking about their position when I did the wiring), to in front of the spar so that they can connect to the fule tank :-)
AN fitting installed on right side
Left side AN fitting installed
Moved fuel tank sender to infront of the spar
