Aileron pins have been cut to length and bent as per VANS instructions, the pins will be safety wired once the painting is complete. To use this method required that the centre hing eye be broken out of the hinge in teh aileron and the two eye's on either side of it in the wing are also removed.
I have installed the aileron pins using one of the VANS sugggested options.
