Eddie's Zodiac XL Project
Date:  11-24-2008
Number of Hours:  4.00
Brief Description:  Installed last 2 outside baffels
Ian came over last night to help install the two outboard ribs, and make up the snap fittings (file a groove on the inside to allow the wire for the capacitive sender to slide through). While Ian was filing grooves, I was un-bending the fuel line vent tube. Once it was unrolled to the correct length it was cut and test fitted. With this done we moved onto installing the second last outboard rib. This went in really easily, however that should have been an omen, because the outboard rib itself was a real pain to get located, after much swearing, we got the first few rivets to slide into place and it was pretty much all done. I have to buy myself a awl, to use to center the sink and rib rivet holes, this gets a bit hard once you Proseal applied....
Last rib to be installed with wiring and fuel vent line
Capacitive sender installed and wired on the outboard side
Outboard rib riveted and prosealed inplace
