Brief Description: Drilled fiberglass tips to the left and right elev
Installing the fiberglass tips took a little more effort then I expected as both tips where compressed and had to be expanded to fit into the elevator tips properly, I used a heat gun to soften the fiberglass and then jammed some sponge into each tip to hold it apart while it cooled. This worked quite well, and once both tips where cool I glued some aluminium strips into each tip so that the rivets would have something to hold onto.
