This evening I started on the rudder, the skins are quite thin so more care needs to be taken, the first step was to cut all the stiffeners and then trim the rear angle, the stiffeners tehn get clecoed in place so that you can mark where they need to be cut at the front to bring them down to the correct size.
Stiffeners cut and installed on the left rudder skin
