Once all the ribs are set, its time to rivet them to HS-6091PP, I ended up chipping the primer a little until I added masking tape to the outside of the bucking bar. I have to admit that bucking rivets gets easier as you move along and your confidence builds, anyhow, the bottom of the stab is done. Onto the top surface.
