The next step was to blind rivet HS-708 to the nose rib and front spar, its a little squeeze in there but with a little patience I got the job done, the tip rib gets set using dome head rivets, the dome head rivet set is a little harder to use, but a little masking tape stops it slipping off the rivet.
