Eddie's Zodiac XL Project
Date:  1-10-2010
Number of Hours:  4.00
Brief Description:  Rivet sides and install plate nuts
As I was re-asembling the fuse I realised there where a few palte nuts on the outboard floor ribs that had not been installed, also the plate nuts for the bottom of the rear baggage compartment, so I installed these, better now then alter when accessw is limitied.
I also installed the elevator push tubes as its much easier to do this now when you bring the front and rear sections together.
Elevator push to assembled and installed
Started on the riveting of the vertical spar supports right side
Started on the riveting of the vertical spar supports left side
