Eddie's Zodiac XL Project
RV-7
Drilled longerons and installed firewall
This evening I finished back drilling the top longerons and then followed the instructions for installing the firewall.
After re-reading the instructions three times they finally made sense, and I partially drilled and clamped the firewall into place as per step one.
I have now taken a break as suggested...
Tomorrow I'll check the firewall to side skin edge distance and then see whats needs ot be done next
I only took one photo tonight, but as part of the firewall install the bottom floor is also clecoed in place..
Longerons drilled and firewall installed
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
