Brief Description: Tech councilor inspection right wing
Martin Ongley my Tech Councilor came over this morning to inpect the quality of workmanship of the right wing before I rivet on the bottom skin. There are a few rivets that should be drilled out and replaced with an oops rivet, as they have been driven a little to hard and have caused the dimple in the skin to split. So the advice is its better to replace them now rather then waiting for a crack to occur and the rivet to work loose.
I will remove any offending rivets this afternoon and replace with the next size rivet. The saving grace of these rivets is that the head size remains the same, so you won't be able to tell.
Otherwise Martin is happy with the workmansship so far.
Martin inspecting the quality of the work before closing of the wing
