Eddie's Zodiac XL Project
Date:  3-30-2009
Brief Description:  Fuel tank stiffeners, drain and filler
Last night I started work on the right tank, Ian came over and gave me a hand to hold everything in place, insert rivets etc. once this was done I back riveted the stiffeners, 15 minutes and it was all done. The fuel drain was then riveted into place before a quick clean up, and then moving onto the filler neck on the top side of the tank. With this complete I gave the tops of the rivets a coat of proseal to make sure there are no leaks and then we tidied up the tools before the proseal started to set.
Filler cap neck riveted adn prosealed
Tank stiffeners prosealed and riveted into place
Fuel drain riveted and prosealed
