Brief Description: Capacitive fuel senders and tank stiffeners
I have been going slow over the last few weeks, fighting a cold etc. but today I decided to get stuck into all the manufacturing requried so that you can finish off the tank. 1. Fuel senders 2. Tank stiffeners 3. Fuel cap 4. Fuel drain 5. Inboard tank fuel fittings etc.
Inboard sender mounted onto rib
Sender mounted on rib and installed into tank for test fitting
