Brief Description: Rivet ribs to front and rear spar
The right wing is slowly coming along, I have to remove the bottom skins which are clecoed on at the moment to allow me to finish setting the bottom rivets into the rear spar and ribs, the only hassle at the moment is the mosquitoes at dusk which are really bad after all the rain we have had.
Rivets into main spar for all the main ribs
Most of the rivets have been set into the rear spar
The most outboard rib with flush rivets set on the rear of the spar
