Eddie's Zodiac XL Project
RV-7
Tie down bracket
After the initial wing prep I started on nthe tie down bracket and spacers, once it was all back drilled, it was bolted in place and the aileron control horn attached and nuts torked to the correct value.
Tie down bracket back drilled and etch primed
spacers back drilled adn etch primed
Aileron bracket bolted in place
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
