Eddie's Zodiac XL Project
RV-7
Pop rivet forward rudder skins
Now to do the fiberglass bits...yuck, as you can see the top fairing has just been inserted into the rudder, the bottom fairing needs a little triming before it can be fitted around the control horns.
View from the bottom looking into the rudder
Completed rudder with leading edge pop riveted
View of the other side
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
