Eddie's Zodiac XL Project
Date:  4-12-2008
Manual Reference:  HS-609PP
Brief Description:  Prepared both rear support doublers
To give myself a break from preparing the wing ribs I decided to actually make a start on the horizontal stabiliser, the first task is to break the edge of the two HS-609PP support doublers so that they sit into the radius of the rear spar of the horizontal stab. The vixen file works really well for this, but the clean up exercise to remove file makes etc. takes just a little longer, but it was a nice change and I have my first actual component made.
Part fo the drawings for the horizontal stab
The two halves fo the rear spar joined with the two doublers
Ends of the doublers with 1/4 radius and polished
