Eddie's Zodiac XL Project
Date:  6-11-2012
Number of Hours:  5.00
Brief Description:  Rigged the ailerons and installed wheel spats
Anne-Marie came with me this morning so that I could rig the ailerons properly, this is a real pain in the butt exercise as everything affects everything else.
2.5 hours and I had the throws even and the ailerons level with the control sticks centered.
Aileron throw;
Left and Right Up 30
Left and Right Dw 17
I then went over everything and ensured it was locked off and marked it with orange troque indicator.
I also re-cut the left side wing root fairing to the correct size, still need to do the right, but I should be able to use the left as a template and then etch prime and paint if it ever warms up enough.
Big thanks to Ian for find me some spare aluminium.
Looks much nicer with its gear leg fairings and pants on
Head on view
Head on view
Cleanign up after the install
