Brief Description: Painted cowl, rudder and re-did stab
Masked up for the cowl, stabiliser and rudder, the stab had water marks in it from when the spray gun spat water at both top surfaces, so it ruined the finish and needed to be rubbed back and re-painted.
Next step is to mask up for the black stripe on the fuselage sides, cowl and the tip of the rudder and vertical stab.
Strip to match fuselage painted on cowl
Horizontal adn vertical stab repainted because of water splatter from spray gun
