Eddie's Zodiac XL Project
RV-7
Pinholes
I have sanded both cowl halves twice, and the bottom cowl is now in primer, with more sanding and pin holes to be filled, the top has a slurry of epoxy and filler. I am trying two different methods to see what might work the best.
Bottomowl in primer, still needs another sand
Other side
Top with filler in the pin holes, more sanding
RV-7 Home
2573
Ailerons
Brakes
Center Fuselage
Centre spar
Cowling
Fairing
Firewall
Flap assembly
Flight testing
Front Fuselage
FWF
Instrument panel
219
Rear turtle deck
Roll Bar
Seats
Spinner
Vertical Stab
Wheels and brakes
554
Zodiac 601 XL Home
