Eddie's Zodiac XL Project
Date:  1-3-2012
Number of Hours:  1.50
Brief Description:  Fixed wiring mistake
This is the link to my first engine start;
http://youtu.be/fXulTjqwqLs
This afternoon I checked the wiring to my left wing and found that I had connected the strobe wires to the wing lights and visa versa, swapped them over and re-tested, and all working properly now.
Also changed the pulse count on the tacho to 0.5 from 1 in the skyview, so this should solve the problem with the rpm reading double the actual value.
The setting is under SETUP MENU > EMS SETUP > ENGINE INFORMATION.
Many thanks to Russ Dent who posted this info in answer to my question on the Dynon discussion forum.
