Brief Description: Installed the right side brakes
This was the biggest pain so far, the spat bracket has to be spaced away from the brake disc using some 13/32 spacers you make from some aluminium tubing, also the brakes supplied are both oriented in the same way so you have to remove the bleeder valve which you can see at the top of the brake caliper and place in the bottom position. Hopefully the left side is much easier.
